booker_ch Posted April 19, 2025 Share Posted April 19, 2025 Hello I have an Hx Effects on my pedal board, actual with a cheap volume pedal made of plastic. I wanted to exchange it against something more stable and bought the Mission Engineering EP1-L6-BK. Connected with a standard stereo cable it's working for nothing (0%) or full volume (100%) as soon as I lift it a little bit from the "0" position I have already full volume. Did also try it on the Hx effects only without the other effects and programmed a new file in the Hx effects with the volume button only after I did the learn progress. I have no idea what else I can do - any hints ? best Peter Quote Link to comment Share on other sites More sharing options...
datacommando Posted April 19, 2025 Share Posted April 19, 2025 On 4/19/2025 at 8:19 PM, booker_ch said: Mission Engineering EP1-L6-BK. Connected with a standard stereo cable I have no idea what else I can do - any hints ? best Peter Hello Peter, From the Mission Engineering page for the EP1-L6 Expression Pedal. ”The Mission EP1-L6 connects to the Line 6 device with a single TS cable. TRS cables are not required for Line 6 expression pedals. TRS expression pedals are not compatible with most Line 6 products. Line 6 specific pedals should be used with Line 6 devices.” Your standard Stereo cable is TRS - Tip/Ring/Sleeve is not compatible. Use a regular cable. TRS cables are used for Amp channel switching. From the HX Effects 3.80 Owners Manual. Alternatively, either jack can be connected to your traditional guitar amp to switch its channels or turn its reverb on and off. Use a TRS cable for dual operation (A=tip, B=ring). To set this jack’s function. See “Global Settings > Preferences” Hope this helps/makes sense. Quote Link to comment Share on other sites More sharing options...
