Rossco02 Posted April 25 Share Posted April 25 So I've had my PodGo pretty much since it came out and had no issues at all. Was working fine when I went on holiday. Came back turned it on and nothing from the main outputs (Right or Left). Plugged the output into Ampout and all working okay. Plugged into FX loop send (and then enabled it) and all okay. FX Loop not normally enabled so that's not the issue. "wiggled" the cable in both outputs and no sounds. Check all global settings (not that I'd change them anyway) and all okay. Did latest update (as I hadn't got around to it) and not made any difference. Anyone have any other ideas or experienced the same problem OR anyone recommend UK service engineer/centre to contact? I think Sontec is the offical centre would be interested if anyone had any experience of them. Thanks in advance. Quote Link to comment Share on other sites More sharing options...
Sqawk Posted April 25 Share Posted April 25 While in Global settings did you look to see if the volume knob is set to "Both" main out and Amp out? Quote Link to comment Share on other sites More sharing options...
