Rickardgraff Posted May 5, 2025 Share Posted May 5, 2025 I have a Catalyst cx 60 since a week, and cant get the sound in speaker sound ok. With headphones the sound is good, but in the cabinet speaker it is sharp anemic and sounds like a 4" speaker. Anyone else had this problem? Quote Link to comment Share on other sites More sharing options...
rd2rk Posted May 6, 2025 Share Posted May 6, 2025 If you bought it new, return it. If you bought it used, check to see if the speaker leads are connected correctly. The connectors on the speaker are marked +-. If you have another amp, connect it to the speaker to test the speaker itself. If the speaker is OK, then you're probably screwed. Open a support ticket in case it's a known issue. L6 is known to sometimes fix such issues even out of warranty. Quote Link to comment Share on other sites More sharing options...
