HX FX Switch LED Light question
musicjuice
Hi!
Question: I have an amp that responds to MIDI PC and CC.
I have set my HX FX so that in one of my presets (01B) one of the switches (switch 5 in this case) is linked to command center, sending a Bank/Program Message (Base midi ch, Bank CC0 none, Bank CC32 none, Program 57).
When I press it it switches my amp to Master 2 (so that I can solo on the same preset).
When I press the switch the corresponding light goes on when pressed and off when pressed again, as with any other block turned of/off.
I've put the same command in another preset 12C and in this preset when I press the assigned switch the lights only turns on when I press it and won't stay on...it goes off as soon as I lift my foot.
I can't find any setting or any difference in how the switches are configured in the two presets, it's just the same function, only in preset 01B the light turns on when pressed and off when pressed again, in preset 12B the light only turns on for a second when the switch is pressed, then goes of...
Any help???
I've made a video of this, if needed.
Hi, thanks for replying.
Is latching vs momentary a 'per preset' setting then?
As in preset 1C is latching and in preset 12B is momentary!
As far as I can remember latching/momentary is a global setting and it affects all presets...
In Command Center you can set up footswitches per preset. The CC Toggle Commands you're using offer Latch and Momentary as switching options.
