spats711 Posted August 2, 2025 Share Posted August 2, 2025 Hi. New Helix user here (after spending 20 years with boss mfx!) so apologies if there is an obvious answer to this question! In snapshot mode, I would like the epxression pedal to have three settings for the eq block - heel down (eq db=0) half way (eq db =+2) toe down (eq db = +4). Not for every snapshot but just a selected few. My hope is that this will allow me to have three different levels (one for rhythm, one for boost riffs and one for lead) in just one snapshot. I hope that makes sense! is this possible? Thanks Quote Link to comment Share on other sites More sharing options...
silverhead Posted August 2, 2025 Share Posted August 2, 2025 Certainly. Assign the Level parameter of your EQ block to the Snapshot controller (push and rotate the parameter knob; you will see the value turn white and become bracketed). Select each Snapshot one at a time, set the desired level, and Save the preset before moving to the next Snapshot. Quote Link to comment Share on other sites More sharing options...
