BaylorPRSer Posted August 29, 2025 Share Posted August 29, 2025 Someone suggested I use a DI box with my POD HD500x. Want to make sure I understand the situation correctly. "A DI box converts high-impedance, unbalanced instrument signals into low-impedance, balanced microphone signals, allowing for clean signal transmission over long cable runs and direct connection to mixers and audio interfaces by reducing noise and interference. It essentially acts as a bridge, matching the instrument's signal characteristics to the equipment's microphone inputs, which are designed for low-impedance, balanced signals" According to the internet^ So for the POD HD500x, it would be useful if the mixer did not have enough available XLR inputs for you. If you're go direct into the house mixer with XLR, then there's no benefit to using a DI box. Am I understanding the situation correctly? Quote Link to comment Share on other sites More sharing options...
hurghanico Posted August 29, 2025 Share Posted August 29, 2025 The POD HD500X provides already both unbalanced jack outputs and balanced XLR outputs. The jack outputs can be set to either LINE or MIC level using the dedicated switch near the expression pedal. The balanced XLR outputs are MIC-level only and are particularly suitable for very long cables. In conclusion, I would say that with the POD HD500X, there's no advantage to adding a DI box. If you want to connect the POD to the mixer's MIC inputs with very long cables, simply use the POD XLR outputs; nothing else is really needed. _______________________________________________________________________________________________________________________________________________________________________ All about POD HD500/X help and useful tips Quote Link to comment Share on other sites More sharing options...
