rockerviktor Posted September 24, 2025 Share Posted September 24, 2025 I believe there are 2 main ways you can route your signal chain when using the 4 cable method with a real amp. 1. Use the [FX Loop 1] block in the middle of the signal chain. (Picture 1) 2. Use the [Send 1/2] output option for the upper signal path, and the [Return 1] input option on the lower signal path. (Picture 2) Both work perfectly, both have their advantages, disadvantages. But what I don't quite understand that they sound quite different. Method 1 sounds more mid forward, while method 2 sounds a bit more scooped (reminds me of what a BBE Sonic Maximizer does). Did anyone else notice this? Is there an obvious reason behind this that I'm missing? Quote Link to comment Share on other sites More sharing options...
Schmalle Posted September 24, 2025 Share Posted September 24, 2025 I can't open your attachments. You're probably encoutering phasing artifacts. If you mix in the FX loop signal partially this can happen, use Mix at 100%. Quote Link to comment Share on other sites More sharing options...
