sorrelm Posted April 21, 2014 Share Posted April 21, 2014 Hello, I have absolutely same problem with Lowdown 15, like the issue: http://line6.com/supportarchivenew/thread/14959 It means when I switch power on - All the lights from the "Clear, R&B, Rock and Grind" settings are burning and the threshold light is blinking. After factory setting its not better. Because it seems to me that it should be common problem, is it way how to fix it. If it could be problem of the power supply circuit or if it is for example more software problem? Thaks a lot Martin Quote Link to comment Share on other sites More sharing options...
Shakey64 Posted April 21, 2014 Share Posted April 21, 2014 Did you mean to post this in the Amplifi section? Quote Link to comment Share on other sites More sharing options...
TheRealZap Posted April 21, 2014 Share Posted April 21, 2014 I put it in the right area. Quote Link to comment Share on other sites More sharing options...
NicTe Posted June 18, 2014 Share Posted June 18, 2014 Bump? I suffer for the very same problem. Should I create another thread in the "amplifier" sub-forum ? Quote Link to comment Share on other sites More sharing options...
