LordOfMisrule Posted December 26, 2025 Share Posted December 26, 2025 New to the entire modeler realm, so bare with me. I was interested in buying a HX Stomp XL to replace my current pedalboard and tube amp but was wondering if it is possible to create this setup: I want to use an amp and cab model to send to the front of house, but also want to use an on-stage cab. Can I send a signal to FOH with an amp model and cab model, and send a different signal to my on-stage cab with only an amp model and without the cab model? Cheers! Quote Link to comment Share on other sites More sharing options...
silverhead Posted December 26, 2025 Share Posted December 26, 2025 Yes. In your Stomp XL preset use separate amp and cab models (not an integrated amp+cab) and place a SEND block between the amp and cab blocks in the signal chain. Connect the SEND output to the amp’s cab input. Connect the main outputs to FOH. Make sure the output and input levels match. You can position any FX blocks before or after the SEND block depending on whether you want them to be heard in your onstage cab or not. 1 2 Quote Link to comment Share on other sites More sharing options...
