flux1968 Posted December 26, 2025 Share Posted December 26, 2025 After updating to the latest firmware, the reverb seems to have stopped working. When I push the button, the orange light comes on, but when I move the selector knob, it only selects the amp types. All the other effects work fine. Any idea why this is, and how to fix it? Quote Link to comment Share on other sites More sharing options...
rd2rk Posted December 27, 2025 Share Posted December 27, 2025 You have to hold the FX button down until the selector switch blinks and then dims. Then press the TAP button until the FX LED you pressed (FX1 or FX2) displays the color code for the type of effect you want. Then turn the selector to the desired effect in that category and press the FX button again to confirm your selection. Download the Catalyst CX Family Pilot's Guide and see page 10. Quote Link to comment Share on other sites More sharing options...
flux1968 Posted January 3 Author Share Posted January 3 On 12/26/2025 at 10:55 PM, rd2rk said: You have to hold the FX button down until the selector switch blinks and then dims. Then press the TAP button until the FX LED you pressed (FX1 or FX2) displays the color code for the type of effect you want. Then turn the selector to the desired effect in that category and press the FX button again to confirm your selection. Download the Catalyst CX Family Pilot's Guide and see page 10. Thanks, but it's not the CX model I'm asking about, just a Catalyst 60. On the Catalyst 60, the directions you provided are for the other effects, which work fine. The reverb is a separate function. Quote Link to comment Share on other sites More sharing options...
rd2rk Posted January 3 Share Posted January 3 FYI - if you update your FW your plain vanilla Catalyst will magically BECOME A CX! I did it to my Catalyst - it's GREAT! But, if for some unfathomable reason you don't WANT a better, more powerful Catalyst, FOR FREE, below is from the original Catalyst Pilot's Guide: 1. Press the REVERB button to enable the Reverb 2. Press again to switch the Reverb off. 3. Like the EFFECTS, press and hold the REVERB button for two seconds to enter reverb selection mode. The AMP SELECTOR encoder LED ring will dim, and you can use the SELECTOR to scroll through the six different reverbs. Press the REVERB button again to exit selection mode. Remember to press and hold CH A or B to save your reverb settings to that preset. If the above doesn't work and a factory reset doesn't fix it, open a support ticket. 1 Quote Link to comment Share on other sites More sharing options...
flux1968 Posted January 8 Author Share Posted January 8 On 1/3/2026 at 6:07 PM, rd2rk said: FYI - if you update your FW your plain vanilla Catalyst will magically BECOME A CX! I did it to my Catalyst - it's GREAT! But, if for some unfathomable reason you don't WANT a better, more powerful Catalyst, FOR FREE, below is from the original Catalyst Pilot's Guide: 1. Press the REVERB button to enable the Reverb 2. Press again to switch the Reverb off. 3. Like the EFFECTS, press and hold the REVERB button for two seconds to enter reverb selection mode. The AMP SELECTOR encoder LED ring will dim, and you can use the SELECTOR to scroll through the six different reverbs. Press the REVERB button again to exit selection mode. Remember to press and hold CH A or B to save your reverb settings to that preset. If the above doesn't work and a factory reset doesn't fix it, open a support ticket. That was exactly it! Thanks! Quote Link to comment Share on other sites More sharing options...
