mpromusic Posted Saturday at 07:17 PM Share Posted Saturday at 07:17 PM Hi There: I am new to HX Effects - really starting to dig this. Question for all you smart folks out there - is there a way to add a external switch to trigger an effect that is not added, or showing on the one of the 6 switches? I am trying to add an overall VOLUME Boast for solos without taking up one of the switches - it is more of a global thing. Thinking I can add switch or pedal to the expression pedal input and have that trigger a db boost like I do with my Quad Cortext? It's always there when I need it kind of thing? If not, how would you suggest i do this? I use all 6 of the switches on the HX. Thank you in advance. Marc Quote Link to comment Share on other sites More sharing options...
enjalt Posted 1 hour ago Share Posted 1 hour ago Actually you have several methods. For example you can use a send /return bloc if the device you use for the boost can be used alone. In this case you'll have to insert the bloc send/return in your signal chain Or you can use MIDI using an external midi pedal, add a volume/gain bloc and in command center to set the activation. Anyway you'll have to put a bloc in your signal chain. This method can be used with an external EXP Pedal Quote Link to comment Share on other sites More sharing options...
