Mosat Posted April 1 Share Posted April 1 Play view: For those using Stadium Floor: I only use a few presets and go back and forth between them. But when I go back, Play view reverts to the signal chain Home view. Is there a way to keep it in Play view? I need Play view by default. Quote Link to comment Share on other sites More sharing options...
joepepe Posted April 1 Share Posted April 1 I have the same issue - and already reported to Line6/Yamaha 1 Quote Link to comment Share on other sites More sharing options...
silverhead Posted April 1 Share Posted April 1 In Global Settings -> Switches/Pedals you will find a parameter called Preset Mode Return. Perhaps that’s what you want? Quote Link to comment Share on other sites More sharing options...
Mosat Posted April 1 Author Share Posted April 1 On 4/1/2026 at 3:58 PM, silverhead said: In Global Settings -> Switches/Pedals you will find a parameter called Preset Mode Return. Perhaps that’s what you want? Ah, I shall try it. Thanks. Quote Link to comment Share on other sites More sharing options...
Mosat Posted April 1 Author Share Posted April 1 On 4/1/2026 at 5:11 PM, Mosat said: Ah, I shall try it. Thanks. No luck. Preset Mode is greyed out as an option in Global Settings. Something is definitely amiss. There is no rhyme or reason as to which preset appears in which mode at any particular time. There is nothing consistent. Quote Link to comment Share on other sites More sharing options...
joepepe Posted April 2 Share Posted April 2 Line 6 confirmed the irregularily in reverting from Play mode screen to Home/edit screen. It seems to be a bug. To my finding, that was not a problem with the previous firmware version 1 Quote Link to comment Share on other sites More sharing options...
tele_jas Posted Friday at 05:32 PM Share Posted Friday at 05:32 PM I have that issue with the non XL, but I noticed that it's actually working like it should, just not showing the Play View screen. When I step on the mode switch, my preset footswitches light up and when I choose one, they rest of the footswitches light up with the colors and FX I assigned to them. So, if you remember where you're stuff is, you can "get by". Quote Link to comment Share on other sites More sharing options...
joepepe Posted Friday at 07:40 PM Share Posted Friday at 07:40 PM For my understanding it is Not practicabel to return to the Play Screen by touching the Home Button manualy each time - the Play Screen should stay on - should be seen consequently for foot - Control use Quote Link to comment Share on other sites More sharing options...
silverhead Posted Friday at 10:41 PM Share Posted Friday at 10:41 PM On 4/10/2026 at 3:40 PM, joepepe said: For my understanding it is Not practicabel to return to the Play Screen by touching the Home Button manualy each time - the Play Screen should stay on - should be seen consequently for foot - Control use When in Home -> Edit view the Home button is the quickest way to get to the Home -> Play view. But you can do it using the Mode footswitch. Hold it down to activate the More view. From there you can use the assigned footswitches to activate other views, among them the two Home -> Play views you define in Global Settings. Hit the Mode switch again to display the first of those Views. Then the mode switch toggles between those two views. I haven't found a way to get back to Home -> Edit view without bending down to hit the Home button. But, like you, I prefer to stay in Play view. When I want to edit I use the editor app. See Global Settings for details about the different Modes and Views. Quote Link to comment Share on other sites More sharing options...
joepepe Posted yesterday at 06:30 AM Share Posted yesterday at 06:30 AM „Stay in Play Mode“ without bending down to hit Home Button was not a Problem in the previous firmware Quote Link to comment Share on other sites More sharing options...
