Play/Performance View on Stadium Floor
Mosat
Play view: For those using Stadium Floor: I only use a few presets and go back and forth between them. But when I go back, Play view reverts to the signal chain Home view. Is there a way to keep it in Play view? I need Play view by default.
On 4/1/2026 at 3:58 PM, silverhead said:
In Global Settings -> Switches/Pedals you will find a parameter called Preset Mode Return. Perhaps that’s what you want?
Ah, I shall try it. Thanks.
No luck. Preset Mode is greyed out as an option in Global Settings. Something is definitely amiss. There is no rhyme or reason as to which preset appears in which mode at any particular time.  There is nothing consistent.
Line 6 confirmed the irregularily in reverting from Play mode screen to Home/edit screen. It seems to be a bug. To my finding, that was not a problem with the previous  firmware version
