M5 No DSP Audio Output — True Bypass Works
Hello guys!
I’m looking for help diagnosing my Line 6 M5 that currently has no DSP audio output.
Current symptoms:
* Pedal powers on normally
* LCD/display works
* Presets change normally
* True bypass works perfectly
* DSP bypass has NO output
* Most effects have no sound at all
* Some distortion/OD/filter effects produce very weak low-volume output
* Delay/reverb/modulation effects are completely silent
Additional important detail:
Originally, the pedal would randomly RESET/reboot whenever changing presets. After opening the backplate and pressing/reseating some ribbon cables/connectors, the reset issue disappeared completely.
So now:
* preset changing is stable
* but DSP audio is still basically dead
Things I already tried:
* different known-good 9V center-negative adapters
* Zoom G3Xn adapter
* factory reset
* cleaned ribbon cable contacts/connectors with isopropyl alcohol
* reseated internal ribbon cables multiple times
* tested left mono input/output only
What still works:
* true bypass path
* pedal boots normally
* UI/display/controls all work
What does NOT work:
* DSP processed signal path
Questions for experienced M5 repairers:
1. Are there known common failure points on the M5 that match these symptoms?
2. Which voltage rails should I check first?
3. Any known bad capacitors or regulators on the M5?
4. Has anyone seen “true bypass works but DSP path silent” before?
5. Could a ribbon/header issue still cause this even after reseating?
6. Is there a service manual or board schematic available anywhere?
Any advice would really help be
fore I start deeper component-level troubleshooting.
Thanks!
