jonassaav Posted May 24 Share Posted May 24 My AER amplifier has an external effect loop connection. However, it operates in parallel mode, not in serial mode (which I believe is the more common way). This means that if plug in the HX One to this connection, I need to be able to having the HX One to output a completely wet signal. Otherwise the dry signal would double up in the internal mix in the amp which is not good for several reasons. So, does all time based effect presets have a possibility to set the effect level to 100% and effectively completely attenuate the dry signal? The manual is not detailed enough to clarify that. I don’t own an HX One yet, so no, I can’t just try it my self :-) (I do understand that a parallel mode effect loop is only useful for time based effects) Quote Link to comment Share on other sites More sharing options...
