areabassist Posted yesterday at 03:34 PM Share Posted yesterday at 03:34 PM HX FX came up with blank LCDs (backlit, but blank). Still connects to HX Edit and shows patch info. I reseated ribbon cables (the main one had been disconnected) but that did not fix it. I forced Update Mode and successfully updated to the latest version using Line6 Updater. It's still stuck in a loop when I try to boot it up - about every 10 seconds I can hear the relays clicking. These are down to $500 new so I'm not sure it's worth taking to a shop at $120/hr labor plus a board or whatever. Any suggestions? Quote Link to comment Share on other sites More sharing options...
areabassist Posted yesterday at 03:36 PM Author Share Posted yesterday at 03:36 PM Also - I'm using the original power supply, and also tried a 1 spot (1700 ma) with no luck Quote Link to comment Share on other sites More sharing options...
Schmalle Posted yesterday at 06:55 PM Share Posted yesterday at 06:55 PM Now that you've excluded the power supply from the list of possible causes two things come to mind that you can give a try: 1) You mentioned you reseated the "main" ribbon cable. The HX Effects actually contains two primary ribbon cables: The wide main ribbon cable connecting the main processor board to the display/footswitch board. A smaller, secondary ribbon cable that specifically routes power and control data to the upper scribble strip/LCD assembly. If the main processor tries to boot, queries the secondary display board, and receives a short circuit or no response due to a bad connection, the bootloader will crash and force a reset loop. Open it back up. Disconnect both ribbon cables. Clean the gold contact fingers on the ends of the cables using 99% Isopropyl Alcohol and a Q-tip. Ensure they are seated absolutely straight and deeply into their Molex plastic collars before locking them down. 2) Because you just did an update while the unit was in a semi-broken state, it is possible there is a corrupted global settings file or "problem preset" causing a boot crash. Even with blank screens, you can force a hardware reset using the physical switches: Turn the unit OFF. Press and hold Footswitch 6 (top right switch) and the TAP switch simultaneously. Turn the unit ON while holding those down. Keep holding them for about 10-15 seconds. If it successfully clears the state, the boot loop might stop, allowing the displays to spring back to life. Good luck finding the cause of the issue, share if you find it. 1 Quote Link to comment Share on other sites More sharing options...
