najapi8681 Posted August 20 Share Posted August 20 Hey everyone, I’m hoping to tap into the collective brain trust here regarding a bit of a "Frankenstein" studio setup I’ve been putting together. I’ve been a Line 6 user for years—started with an old POD 2.0 and eventually moved up to the Helix ecosystem. Usually, I just plug into my MacBook and go, but I recently decided to try something a bit different for my home studio’s "brain." I managed to get my hands on a decommissioned HP ProLiant DL380 through work, and on paper, it looked like it would be an absolute monster for running DAW sessions with tons of Helix Native instances and IR loaders. It’s rocking an 8 Core 3.2GHz Xeon Gold, and I figured that the raw processing power and high clock speed would make latency a thing of the past. However, I’ve run into a massive headache with audio dropouts and "crackling" whenever I try to use my Line 6 interface via USB. I’ve gone through the usual steps—updating drivers, checking cable lengths, and even trying a dedicated PCIe USB card—but the DPC latency is still all over the place. One specific thing I’ve noticed is that these enterprise servers have incredibly aggressive power management and "C-state" switching in the BIOS to save energy, which seems to be fighting my audio drivers every step of the way. It’s a bit frustrating because the CPU usage barely hits 5% even on heavy projects, but I’m still getting that digital distortion as if the buffer is too low. I’ve tried setting the Windows power profile to "High Performance," but I suspect the server hardware itself is doing some background "housekeeping" that’s interrupting the audio stream. I really want to make this Xeon Gold setup work because the thought of having essentially infinite headroom for plugins is a dream, but I'm starting to wonder if server chipsets are just inherently too "noisy" for real-time pro audio. I’ve read that some people have had luck disabling specific virtualization settings or hyper-threading on server-grade CPUs to stabilize the interrupt timing. I’m curious if anyone here has successfully tamed a ProLiant or a similar Xeon-based rack server for low-latency recording? Are there any specific BIOS-level tweaks for these 8-core Xeon chips that you’ve found to be "make or break" for stable USB audio, or am I just fighting a losing battle against hardware that was never meant to prioritize real-time processing over data throughput? Quote Link to comment Share on other sites More sharing options...
