FenixRizn Posted November 12 Share Posted November 12 I just want to confirm that I am understanding the routing correctly. To stereo process with Helix Stadium Native from within my DAW I have placed (1) instance of Native on a stereo group track. I then add a split path and a merge path, setting the balance of A and B to 100% left and 100% right respectively. I then added mono effect blocks/amp/cabs between the split and merge creating identical effect chains on path A and B. Soloing each left/right track gave me audio for that track only. Also if i understand correctly, I can place stereo effect blocks after the merge such as delay/reverb, and keep the stereo image? And adding a mono block after the merge will effectively kill the stereo image and sum to mono? Hope that I'm getting this right. I really wish they would add a stereo button to simplify this process. Quote Link to comment Share on other sites More sharing options...
silverhead Posted November 13 Share Posted November 13 Have you read the relevant sections in the manual? For instance: https://manuals.line6.com/helix-stadium-native/v1.4/signal-path-routing-options Quote Link to comment Share on other sites More sharing options...
FenixRizn Posted November 14 Author Share Posted November 14 Of course, the manual was the first thing I read. The problem with the manual is they crammed so many different routing options into the section that I found it really easy to get lost. Thus the reason I came here hoping for someone to provide a simple answer and/or simply confirm that I am already headed in the right direction. Quote Link to comment Share on other sites More sharing options...
