bbehrens Posted 13 hours ago Share Posted 13 hours ago If you add a 1-switch looper and automatic footswitch assignment is enabled, then the 1-switch looper should be assigned to footswitch A1 (depending on your setup). If you then manually assign the 1-switch looper to another footswitch (e.g. A11), then the recording will stop after 1 second. Further, if you remove the manual footswitch assignment (set it to "None"), then the scribble strip will simply show "Transport". NOTE: This occurs using the Stadium Editor App v1.4.0 and does not exhibit this behavior when editing on the Stadium Unit itself. This was tested only with the Stadium XL and Stadium Editor App v1.4.0. I have opened a Ticket with Line 6 regarding this issue. Quote Link to comment Share on other sites More sharing options...
