fotofx Posted June 5, 2014 Share Posted June 5, 2014 I have a fairly hot condenser mic. How do I pad a channel? I know I must just be missing it someplace. Quote Link to comment Share on other sites More sharing options...
SiWatts69 Posted June 5, 2014 Share Posted June 5, 2014 AFAIK you shouldn't need to "PAD" the mic. Whilst it is picking up its normal signal levels, just run autotrim on it and the trim level should be set more appropriately. If it's running too hot still afterwards, you can manually decrease the trim level within deep tweak or just try autotrimming again but with the sound source delivering a level closer to their/its performance level. Quote Link to comment Share on other sites More sharing options...
gordwait Posted June 9, 2014 Share Posted June 9, 2014 Deep tweak, input section, adjust trim either automagically (autotrim) or turn the dial and set it. The trim dial _is_ your input pad setting.. Quote Link to comment Share on other sites More sharing options...
