davidfi01 Posted August 24, 2014 Share Posted August 24, 2014 I recently purchased Amplifi 75 and already have a FBV SB MII. The FBV seems to lock up when the ios app is used. Scenario as follows: 1) flash both FBV and A75 to latest firmware. 2) connect ipad via blue tooth and sync. 3) FBV works great including Wah/ Volume pedal. 4) load song from iTunes library. Match tone. FBV board hangs up. None of the selectors work. Wah/Volume does not change. 5) only way to get FBV to work again is to unplug and plug it back in Is there anything I can do to prevent this lock up? When is new firmware due out? Thanks Quote Link to comment Share on other sites More sharing options...
wilson69978 Posted September 9, 2014 Share Posted September 9, 2014 Hello my friend: I had the same trouble David, only I was using the fvb express pedal. It seems like the amp is getting confused with info coming from the app and the pedal at the same time. When I close the app the pedal works fine. I don't know if this is a bug they can fix or not, but if you want the pedal to work, just close the app. You don't need to control the amp using both anyway, right? Quote Link to comment Share on other sites More sharing options...
