Barista_Bum Posted August 24, 2014 Share Posted August 24, 2014 I was playing this morning and the JTV-69 suddenly switched to dropped d. Tuning wheel is set to standard. Doesn't matter what the model / pickup selection is. Same thing through VDI, 1/4" with & without POD X3Live, battery, XPS, whatever. Reflashed/upgraded all firmware and drivers, but no change. Anybody seen this before? P.S. Everything sounds a-ok when I use the magnetic pups. Also, Workbench detuning doesn't seem allow me to raise up the affected string. Quote Link to comment Share on other sites More sharing options...
clay-man Posted August 25, 2014 Share Posted August 25, 2014 When I opened up my Variax to fix something, it was having problems with the model select knob and essentially reading 1 bank permanently due to a grounding problem with the coffin. I fixed this by cleaning some stuff up. I assume something in the electronics is having a signal or grounding issue with the tuning knob like my case. I'm not really sure about a solution though. Have you tried going into workbench and changing the drop D slot to a different tuning? Quote Link to comment Share on other sites More sharing options...
Barista_Bum Posted August 25, 2014 Author Share Posted August 25, 2014 Thanks for the reply, Clay. I may crack her open to see what things look like in there. Workbench HD tuning doesn't seem to have any affect on the problem, which I think is doubly weird. The tuning wheel does change things, and the open tunings are correct, but all of the standard-based tunings (e.g., Down 1/2 & Down 1) are down a step on string one relative to where they should be for the selected tuning. You mentioned having some difficulty with the model select knob; what was that? I've recently had to press it several times to get it to toggle. Perhaps the two problems are related. Quote Link to comment Share on other sites More sharing options...
Charlie_Watt Posted August 25, 2014 Share Posted August 25, 2014 Probably not related. The model select knob problem is widespread. It can bottom out before switching. The cure is to put a small shim in the hole so that the shaft doesn't go in all the way. Easy fix. Quote Link to comment Share on other sites More sharing options...
Barista_Bum Posted August 25, 2014 Author Share Posted August 25, 2014 Thanks, Charlie. Quote Link to comment Share on other sites More sharing options...
clay-man Posted August 25, 2014 Share Posted August 25, 2014 Thanks for the reply, Clay. I may crack her open to see what things look like in there. Workbench HD tuning doesn't seem to have any affect on the problem, which I think is doubly weird. The tuning wheel does change things, and the open tunings are correct, but all of the standard-based tunings (e.g., Down 1/2 & Down 1) are down a step on string one relative to where they should be for the selected tuning. You mentioned having some difficulty with the model select knob; what was that? I've recently had to press it several times to get it to toggle. Perhaps the two problems are related. Well, I'm sure the JTVs aren't assembled like my 600, but mine has a coffin, and when that is grounding incorrectly, it would override the model knob and be stuck on 1 model bank. Quote Link to comment Share on other sites More sharing options...
Charlie_Watt Posted August 25, 2014 Share Posted August 25, 2014 No Coffin in the JTV69. 1 Quote Link to comment Share on other sites More sharing options...
clay-man Posted August 26, 2014 Share Posted August 26, 2014 No Coffin in the JTV69. Which is what makes me question what would interrupt the signal like that. The coffin problem was from short circuiting things right? Quote Link to comment Share on other sites More sharing options...
