drclay Posted September 7, 2014 Share Posted September 7, 2014 I'm using Pod Farm Element VST effects v2.57 in Acid Studio 10. My problem is the effect settings aren't getting saved in the Acid projects. When I reopen the Acid project the Pod effect settings are returned to their defaults. This doesn't happen with other VST plugins I'm using. I also noticed when attempting to save a VST effect preset to a file (*.fxp) using the Pod Element UI I get a 0 byte output fxp file, so of course when I (re)load it, it doesn't do anything. Since other VSTs work I'm suspecting Pod Farm. Is this a design limit or known problem? Thanks DrClay Quote Link to comment Share on other sites More sharing options...
