sperl42 Posted September 18, 2014 Share Posted September 18, 2014 Line 6 officially says that SonicPort VX only works with iphone 5 or bigger. How about iphone 4S with a Lightning to 30pin converter? My iphone 4S currently runs iOS 8, so it should be no big deal. Any answer would be appreciated. kind regards, Stefan Sperling Quote Link to comment Share on other sites More sharing options...
TheRealZap Posted September 18, 2014 Share Posted September 18, 2014 you need this cable: http://www.fullcompass.com/product/457008.html Quote Link to comment Share on other sites More sharing options...
mel999 Posted September 19, 2014 Share Posted September 19, 2014 Will the 30-pin connector delivered with the SonicPort also work with the SonicPort VX? I already own the SonicPort, but want to buy the SonicPort VX and use it with my iPad 3 (30-pin connector) currently under iOS7. Thank you for the answer! Quote Link to comment Share on other sites More sharing options...
TheRealZap Posted September 19, 2014 Share Posted September 19, 2014 according to the part number and the fullcompass site they are the same cable. I'm pretty confident it will work. I too have the ipad 3 and would be curious to hear your feedback. I use my VX with some newer iOS device now with the lightning cable. 1 Quote Link to comment Share on other sites More sharing options...
mel999 Posted September 24, 2014 Share Posted September 24, 2014 The VX works perfectly with the 30-pin connector cable delivered with the Sonic Port (non VX). I only had issues with the Mobile Pod app on my ipad 3. Under iOS 7.0.6 there is no Mobile Pod version working with the VX device, you have to use iOS 7.1 as a minimum. The update to iOS 7.1.2 wasn't too easy with iOS 8.0 already active on air. It's a matter of rebuilding the device with a downloaded ipsw-file, not to forget the time consuming backup and restore of all apps and data. But finally everything ist working like a charm. Thanks for your support! Quote Link to comment Share on other sites More sharing options...
TheRealZap Posted September 24, 2014 Share Posted September 24, 2014 The app is working on ios8 was there a reason you didn't go with the latest? Quote Link to comment Share on other sites More sharing options...
mel999 Posted September 24, 2014 Share Posted September 24, 2014 Many other apps still have problems with iOS 8 or are not working at all. The OS is very new and buggy and I don't want to be a beta tester. I have read that the chance for app crashes with 8.0 is three times as high as with 7.1.x. At least: is my "old" ipad 3 really quick enough für iOS 8? I doubt ... Quote Link to comment Share on other sites More sharing options...
pokeexperte Posted September 26, 2014 Share Posted September 26, 2014 I just tested the Sonic Port VX on an iPad 3 with iOS 8 installed. Worked flawlessly. Quote Link to comment Share on other sites More sharing options...
mel999 Posted October 11, 2014 Share Posted October 11, 2014 Today I tried loading my ipad3 via the supplied usb cable and the 30pin adapter from the sonic port package: doesn't load :( I further experimented with my iphone 5c: here loading only works with the sonic port xv supplied lightning cable, but not with the one from the sonic port package... Seems like I have to replace my ipad 3 with a newer one. Has anyone tried the above mentioned "Line 6 21-34-0230" cable? Does it support loading of the ipad 3? Quote Link to comment Share on other sites More sharing options...
airmanchairman Posted December 26, 2014 Share Posted December 26, 2014 My old Sonic Port cable with the 30-pin connector definitely works with the VX and iPad 3 under iOS8. Mobile POD works satisfactorily and the digital signal is much cleaner and stronger than that of the old SP or analogue interfaces like Peavey's Ampkit Link (which still works acceptably well). The USB connector I used to hook up to a mains charger. The issue is one of charging, and this likely is due to the Retina Display and other battery requirements of this particularly bulky iPad 3 model. I strongly feel that this is the reason Line 6 has not listed it as a compatible device - charging mileage may vary. What I did notice was a 2-3% loss of charge after a few hours of light use, which isn't so bad, and I take this to mean that the VX is actually supporting the iPad 3's battery, otherwise the loss of charge would be much greater within that time. I'm happy enough with its operation so far as to continue to hold out for the hotly-anticipated iPad Pro next year. Any thoughts, esteemed experts? Quote Link to comment Share on other sites More sharing options...
