Output mode setting changing after power down
maxnew40
I had thought that the output mode setting would be saved, but I notice that when I power up my HD500 the output mode gets set to Stack, which sounds really bad into a L2m.
I do have the HD500 connected to the L2m via the L6 link, could that connection be causing my POD500 output mode to change? I know that the connection will cause the speaker to change to electric guitar until you save the preset with the proper speaker mode selected.
-Max
the setting will be saved if you hit save after you change the setting on the L2
however if you power it off, you may need to change from one tome on the pod back to the tone in which the output setting is saved....
this should recall the setting...
