Gweg Posted September 18, 2016 Share Posted September 18, 2016 Hi ! I meet an issue with my Toneport UX2 (the one with the black face). I'm under Windows 10 64 bits Version 1607. My Toneport uses the drivers version 4.2.7.6. When I launch Ezdrummer 2 (version 2.1.4), the soft crashes. I re-launch it, then go to the audio options. In Asio Mode, i don't have the "Line6 UX2 Asio" option. I only have the "Generic Low latency Asio driver". I tried to uninstall the UX2 drivers and re install them. The "Line6 UX2" option appears but when i tried to apply the option, it crashed again. After returning to the audio options, the "Line6 UX2" doesn't appear any more. Does anyone else have the same problem ? Thans in advance for your answer. Quote Link to comment Share on other sites More sharing options...
Gweg Posted September 22, 2016 Author Share Posted September 22, 2016 After a few tests, it seems that the problem comes from Ezdrummer 2. I launched Cubase and i used it about twenty minutes without problems. So i'm going to see with Toontrack. Quote Link to comment Share on other sites More sharing options...
Triryche Posted September 23, 2016 Share Posted September 23, 2016 Try with a fresh reboot and make sure you have all the TT updates. Do you have Product Manager from TT? Also, if any other application explicitly grabs the Line ASIO driver, TT standalones may not see it. Quote Link to comment Share on other sites More sharing options...
Gweg Posted September 26, 2016 Author Share Posted September 26, 2016 I have Product Manager and all the TT updates. When i made the tests, Ezdrummer was the only application running. I made again a few tests. I ran Kontakt and it works perfectly with the Line6 Asio driver. Also, in Cubase 8.5.20, i can select the Line6 Asio driver and everything works, even with the Ezdrummer 2 and Ezmix vsts. It seems that the problem seems to be between the standalone versions and the asio driver. Quote Link to comment Share on other sites More sharing options...
Triryche Posted September 26, 2016 Share Posted September 26, 2016 Did you try rescanning for devices in standalone? My expereince, If I use Line6 ASIO for a DAW, then try any TT standalone, it will not see it unless I reboot my PC, or disable my UX2, re-enable it, then rescan from TT for devices. Quote Link to comment Share on other sites More sharing options...
