tron2012
Members-
20 -
Everything posted by tron2012
Sure, it's a cool idea, I had already thought about it, but I would like to find another kind of solution to fix it.. If only there was a way to be able to set an On/Off state to a footswitch, I could assign two different values for each Snapshot and thus be able to have double the number of snapshots. For example Snapshot Off= Chord # 1 Snapshot On= Chord # 2 . How can I get this?
Hello friends, with my Helix LT I need to play chords of a song by using the 4 OSC effect. I'm using snapshots assigned to footswitches to play every chord, but they are 8 in total per preset and I need to program and play more chords. Can anyone advise me how to have more than 8 snapshots within the same preset? Thanks
Ok, this is my whish list for the next Helix Floor: 1) I believe that one of the strengths of the Helix Floor is the fact that it has an excellent number of Sends / Returns, this makes it unique in the world among the currently existing pedalboards. So this is my Wish/request: add a total of 6 Mono Return Jacks on the rear panel, so we can use up to 3 Stereo Fx pedals within Helix 2 ) Add Studio HD Reverb types and not yet other low to medium quality guitar pedal reverb types : It would be great to have the famous Yamaha reverb rack units, as well as reverb models of the Lexicon or Eventide rack units
Hello people, I love the Variax Bass model ( I don't own it) but I would like to see a new updated model,is there any hope to ask a new Variax bass instrument? It would be a dream for me is there a way to ask that to Line6 Staff?
Please more Bass Amp/Cabs and Mic models, we need them Add to the HX Stomp the support for 1 Expression pedal + Dual Footswtich like the Boss FS-6 at the same time Thank you so much!
Hello guys, it's my first new post here Ok, well, I have some important questions about the HX Stomp Dual FootSwitch/ Exp pedal connections On the rear panel I see a jack Exp 1/2 FS 4/5, my first question : 1) Can I use a double FootSwtich + the Expression pedal? For exapmple, let's say a Boss FS-6 (that I own) and an Exp pedal . I ask that because on the manual I see only the connection example of two Exp pedals, but not a combo of FootSwitch + Pedal...would it be possible? 2) The Exp 1/2 FS 4/5 jack on the rear panel has a TRS connection, so two signalscan be feed,as shown on the page 42 of the manual . In the same page I'm looking to the " One Expression Pedal" it uses only the tip, my question: by using an Y cable inserted into the HX Stomp can I have the TIP connected to the Exp Pedal and the RING to a single Boss FS-5U ? 3) Does the Line6 FBV2 work with Hx Stomp? 4) I have a Line 6 EX-1 Expression pedal, does it work with HX Stomp? Let me know Thaaank you so much!!
Hi folks, today after listening for 100th time to the " The Sixteen Men of Tain", I'm asking to myself if there would be a way create a preset on my HD500X to layer the sound so that the first 3 strings will have an added sound (as already often seen on the Roland GR series ). For instance, let's say to have one only sound within the preset ( a reverbish sound) but when I'll play the first 3 string I will have the addition of a synth-like sound, found only on these specific strings and not on the other ones. Maybe is it possible only with the GK + Gr unit?
Any suggestions? Thanks in Advance
When I'm using a single 1/4" jack Out, it would be better to use a TS or a TRS jack cable? Is the HD500X capable of reamping?
Hi to everyone, since I've decided to use my HD500X as the default soundcard for my laptop, some problems are started too. I'm using my HD500X as the device for both recording and playback, but everytime that I use it in Cubase 8 pro, my Windows 8.1 crashes always! after one minute or more. I see a sky-blue screen, with this message : " DRIVER_IRQL_NOT_LESS_OR_EQUAL (L6PODHD5SE64sys), then everything is restarted. It happens Everytime, also, some other times, my system crashes with some different bug/error system messages, but I've still not been able to write them down. What can I do?
So, the L6 Link Output can't output any sound when the HD500X is used as a soundcard. If I understand right, it will be possible only with the HELIX. Another question is this : when I use the HD500X as a soundcard, can I have the sound output from 4 physical OUTS at the same time? : 2 XLR + 2 1/4" jacks With the same matter, how does it will be the difference compared with the HELIX ? Also, I guess that the HELIX will allows a fast and simple Reamping,right?
Hello, when i'm using my HD500X as main default soundcard device, I've noticed that it doesn't output any sound at the L6 LINK connector on the rear panel (connected to my StageSource L2T), I can listen to the sound only when I'm using the 1/4" OUT connectors , why? Is it the same on the HELIX ?
Hello to everyone, I want to create some multi-tap and/or texure ambient delays with my HD500X, any suggestions or ideas? Let me know Thanks a lot
Ok, I've made a lot of patches and sounds with my present Firmware version, I don't want to lose them, what are the procedures to follow to update my HD500X to the latest 2.6.2 without loosing the patches that I created? Let me know, Thanks.
It's a great pity ! It means that I will not be able to keep the Helix in sync with my DAW and also I will not be able to have the Helix in sync with my Midi Looper ( EHX 45000)
Hi guys and musicians, I have some important questions about the MIDI capabilities of the new HELIX, these are : - Can the HELIX send and receive MIDI CLOCK ? - Can send and receive MIDI CC and MIDI Program Change? Let me know, thanks
Hi, before to purchase I have some questions about the Pod HD 500X : 1) I need to understand how to set the HD500X to send and receive the Midi Clock from external hardware midi devices 2) How to send and receive MidiClock from and to my Cubase? 3) About the Looper behaviour, after that I record one or more loops, do they will be synchronized with internal time-based effects? Also, viceversa do the internal time-based Fx will be synched with the Looper? 4) Do the Looper has a kind of Quantize feature? Let me know, thanks
