39 -
Everything posted by bverdon
Possible new bug? Presets seem to appear changed when nothing changed.
bverdon replied to bverdon's topic in Helix Stadium
In my case... nothing... nothing pressed or changed. It's strange... It hasn't happened again though. Maybe because the stadium was on for over 6 or 8 hours? Will keep an eye on it. Again... not biggie... thought it was strange. I mean... I would select a new preset play for about 10 minutes... not change ANYTHING... and the stadium app would look like I changed something. This happened on several different presets. After a reboot... no longer an issue. -
What is your facebook link?
I am not sure if this was occurring prior to the 1.2.1 update, but now things are a bit more stable and I find myself paying more attention to other things. Now when I have the Stadium app open and NOT changing anything, it looks like after a few minutes of playing, the Stadium app thinks I have modified something. The preset name changes to what appears to be in script mode which signifies something has been modified. I have created a new preset from scratch and it still happens. Not sure if I am the only one and I haven't tried backing things up and performing a factory reset yet. It's really cosmetic ... at least seems that way unless there is some sort of memory leak occurring that is actually changing something. Anyone else notices this?
Bug Report: Snapshot settings not applied correctly in Snapshots
bverdon replied to bbehrens's topic in Helix Stadium
I’m following this thread because the biggest issue right now appears to be snapshot inconsistency. It’s both the most important feature and, unfortunately, the most concerning bug at the moment. Until this gets fixed, the most reliable workaround—although a bit time‑consuming—is to rebuild your patch from scratch. I’ve also had decent success by creating a brand‑new preset (saving frequently) and then copying blocks over from the problematic patch one block at a time. Again, save often. Once all the blocks are in place, you can rebuild and configure your snapshots. One thing I now do EVERY single time I create or update a snapshot is test each snapshot individually BEFORE saving the patch. This has helped me avoid corrupted or inconsistent states. -
I’m curious to hear about everyone’s experiences so far using FRFR systems with the new Stadium. What setups are working best for you, and which amp models you pairing with it?
Appreciate the post... and that you opened a ticket with support. I have had a few issues with snapshots but when I started from scratch and rebuilt the preset, the issue was resolved. If I re-imported the old troublesome preset...the issue is there. Not sure if that helps for a workaround. -
Ah!! Good deal... makes sense. I was thinkin of opening up a ticket... lol! Thank you
Weird.... I don't see that line
Helix Stadium editor disconnects from every ~20 seconds(WiFi connection)
bverdon replied to mlong's topic in Helix Stadium
I just received my Stadium XL yesterday and I was able to stay connected for 4 hours.... no disconnects from the edit software (Windows). I have an eero mesh Wi-Fi (currently connected to the main AP) and my AP is in another room, about 15 feet away. I am connected at 5Ghz speeds on both the PC and the stadium. So... for me very stable. I would suggest that if you are having issues, try to get both devices on the same speed but if your AP is very far away, try to get both devices on the 2.4Ghz channel. This may not be a bug for Line6 to address. -
Hopefully all those who are interested in this support, will chime in. I for one really hope they eventually develop the support for it. I am sure there are much higher priorities but it never hurts to start the conversation.
Ha! just found this one....
Does anyone know of a decent video that illustrates using the effects loop of an amp to send just time based type of effects to a real tube amp? Everything I search targets 4 or 7 cable methods. When I tried to do this to my 5153, nothing but noise. Thanks
Ah... well.. by assigning the topology to a footswitch.. now I can save the desired topology per snapshot within a given patch! Nice! Did not think I could do this... love it! Thank you very much Phil!
What?! This would be awesome... how do I do that?? ok... went back and I see where I can do this... now to see if I can save a clean snapshot with one topology...and the dirty tones with a different topology within the same snapshot...that would be ideal vs. switching via stomp mode. Thank you!!
I like topology III for clean tones and topology II for crunch and heavier tones on my Helix / DT50 setup. I know I could build a new patch but... is there any way to switch the topology within the same snapshot? Thanks
I have a Helix floor unit and a DT50 head and matching 4X12 cab. I feel like I have finally got some good tones through this set up but I have tried mic'ing this puppy up and well... it always sounds buzzy.. not what I am hearing in the room. I have tried multiple mic's ... angles, distances... It's probably the small room I am in just doesn't have decent acoustics... but to my ears (and of course, I am slightly angles from the cab... ) just doesn't sound good mic'd. I would probably have the same issue with other amps in this room.. not sure. Well... messing around today, I sent the same signal I am sending to the DT 50, I split off an xlr with a cab... and feel like this is so much closer to what I am hearing in the room from the amp in the room. I think the volume is slightly high.. but the tone is there. In the short clip of me noodleing I switch between several pickups and I hear/feel the dynamics of what that sounds like in the room with the amp . What I really like about this is, I can play my DT50 while recording a backing track and capture more of a performance kind of feel. Have you guys messed with anything like this? Run into the same issues when mic'ing cabs. Or... am I just really doing everything wrong? Thoughts?
Figured it out... one corrupt preset in my preset list... just went through each one... one of them gave me an error regarding some kind of memory location... deleted it... now everything is working as designed.
I appreciate the link.. good stuff there. Well.. followed the restore to FD's per that doc.. and it came up clean... and on reboot... worked fine... but... Once I performed the recovery, it goes through the updating presets every time I restart it.
But... every time I restart the Helix??
This is happening at every startup... and I suspected it is not normal. Yes... went through normal upgrade process... reset to FD's then performed restore from backup. Not sure I follow you here.. "unless you have imported one or more presets from older firmware since the previous startup". I have imported someone else's files.. and yes.. I am sure it is from previous Firmware... but wouldn't that be the case for anyone that imported a preset? It is starting at preset 1 so.. not sure I can narrow it down per your instructions. Thank you very much for your response!
Not a huge deal... everything seems to be working fine with my Helix Floor unit... just curious.... every time I restart my Helix it goes through the preset rebuild process... which of course take a few minutes. I noticed this since my previous upgrade to 3.10 .. just upgraded today to 3.11 and seeing the same issue. Yes.. I have reset to FD post both firmware upgrades. Thanks
Well... thought I figured it out... .. just selected the digital outs for each path... chose preset1 for AMP 1 and preset2 for AMP 2... and I can have separate topologies ... no matter what I do... both digital outputs share the same topology. If I change DSP digital output on the first shelf, it mates over to to the same settings on the second amp.. and only one AMP model picks up Do you have this working Phil?
Just curious if anyone knows what is supposed to come in the next release of FW for the Helix? I would love to have the ability of choosing separate amps and separate topologies for a pair of DT series amps in series via the L6 cable... I heard a lot of noise about the RAT distortion pedal... what are you guys hoping for?
