Installation Notes of VyzexPocketPOD using VyzexPocketPOD1.17Setup.exe on WINDOWS 10. using
Triryche URL < http://line6.com/software/readeula.html?rid=2732 > which at the time of my entry remains available.
Good practice to always scan installs before actually unzipping / installing. This will return 3 x false positives using Microsoft Defender. ACTION - Proceed.
UNZIP file VyzexPocketPOD1.17Setup.exe.zip
Run VyzexPocketPOD1.17Setup.exe to install VyzexPocketPOD
On completion - Press your WINDOWS KEY and Vyzex Pocket Pod should be listed at the top under recently added.
Right mouse click on VyzexPocketPOD select MORE, Left mouse click open file location.
An explorer windows will open and the RUN file shortcut <Vyzex Pocket POD> will be highlighted.
Right mouse click on highlighted shortcut Vyzex Pocket POD, from drop down menu Left mouse click on PROPERTIES
Left mouse click Compatiblity TAB
Under compatibility mode Left mouse click on the tick box to insert a tick for Run this program in compatilibity mode for <see attached 1 >
From the drop down menu select Windows 7
Click OK
Run the Vyzex Pocket POD program from your windows 10 OS. <see attached 2>
