redeveredev
    4
Everything posted by redeveredev
  1. Booted up the preset this morning and wasn't getting the same issue... very bizarre... If it happens again I'll post the preset and/or contact support Could've been something to do with the firmware update? Only got it yesterday so potentially It needed a restart... Thank you though!
  2. Yeh, the signal is definitely processed by path 2. I have both paths set to output on the main stereo output (using headphones currently) so that I would hear both at once, but the problem is I'm getting signal into path 2 when I feel that I shouldn't be (I can tell because of the indicator on the input node) Cheers, redev
  3. Possibly a bug or possibly something I'm not doing right: I'm trying to use path 1 for a guitar using the Guitar Input, and trying to use path 2 for a bass guitar using the Aux Input (found on the back) When I set this up, so that Path 1 uses "Guitar" as the input, and Path 2 uses "Aux" (neither are using the Multi-Input), signal from the front Guitar port is always sent to Path 1 AND Path 2, when I would expect it to be sent to Path 1 only. If I use the return jacks I can get it to work, but then I'm losing one of the return slots. Is this a confirmed bug? Ta very much, redev
