MickKnipfler Posted October 22, 2014 Share Posted October 22, 2014 OK so my Sonic Port VX arrived this morning. I downloaded the driver, plugged it in to a USB port and......nothing. No sound through the headphones when I play a video on Youtube, no sound when I plug a guitar in and play it. Please assume, I know absolutely nothing......... Quote Link to comment Share on other sites More sharing options...
MickKnipfler Posted October 22, 2014 Author Share Posted October 22, 2014 When I plug it in to my USB port, it actually stops Youtube from playing Quote Link to comment Share on other sites More sharing options...
fflbrgst Posted October 22, 2014 Share Posted October 22, 2014 You have to select the Sonic Port as your default audio playback device in Windows. Quote Link to comment Share on other sites More sharing options...
MickKnipfler Posted October 22, 2014 Author Share Posted October 22, 2014 Doesn't it just recognise it? Also, how do I get different amps & effects? Mobile POD looks as though it's only for ios Quote Link to comment Share on other sites More sharing options...
MickKnipfler Posted October 22, 2014 Author Share Posted October 22, 2014 If I go into my Audio Manager, it shows my Sonic Port as my default device and then locks up saying 'Windows ShellCommon Dll is not responding' Quote Link to comment Share on other sites More sharing options...
MickKnipfler Posted October 22, 2014 Author Share Posted October 22, 2014 My POD HD500 works fine BTW Quote Link to comment Share on other sites More sharing options...
MickKnipfler Posted October 22, 2014 Author Share Posted October 22, 2014 If I go to the Line 6 Audio-Midi Devices application, it says 'no devices connected' Quote Link to comment Share on other sites More sharing options...
MickKnipfler Posted October 22, 2014 Author Share Posted October 22, 2014 When I first plug it in to a USB port, a red light comes on but then goes off. Is that correct? Quote Link to comment Share on other sites More sharing options...
Brazzy Posted October 22, 2014 Share Posted October 22, 2014 Install the VX drivers before plugging it in as per the manual. Check out the manual See this>>> Quote Link to comment Share on other sites More sharing options...
MickKnipfler Posted October 22, 2014 Author Share Posted October 22, 2014 Yep did that....then ran the exe file to install the driver Quote Link to comment Share on other sites More sharing options...
Brazzy Posted October 22, 2014 Share Posted October 22, 2014 (edited) Yep did that....then ran the exe file to install the driver Oh wait that didn't work? Did you ever plug the VX in before installing the driver? Edited October 22, 2014 by Brazzy Quote Link to comment Share on other sites More sharing options...
MickKnipfler Posted October 22, 2014 Author Share Posted October 22, 2014 I did but then unplugged it before loading the driver Quote Link to comment Share on other sites More sharing options...
Brazzy Posted October 22, 2014 Share Posted October 22, 2014 Maybe you need to uninstall whatever windows installed automatically first and start over. You can use USBDeview in administrative mode to uninstall the driver in question and then restart your computer and install the correct driver (maybe you should restart again) and then plug the VX in. Might be an easier way though. 1 Quote Link to comment Share on other sites More sharing options...
MickKnipfler Posted October 22, 2014 Author Share Posted October 22, 2014 OK, there are 2 created today. One is the Sonic port. Maybe I should delete both and start again..... Quote Link to comment Share on other sites More sharing options...
Brazzy Posted October 22, 2014 Share Posted October 22, 2014 OK, there are 2 created today. One is the Sonic port. Maybe I should delete both and start again..... Wont hurt to uninstall both, restart and reinstall. Just make sure you run usbdeview in admin or the uninstall won't happen. Quote Link to comment Share on other sites More sharing options...
MickKnipfler Posted October 22, 2014 Author Share Posted October 22, 2014 OK, that worked. I can now hear Youtube through the device and also play my guitar at the same time (although youtube is a lot louder do I've had to turn it right down. The next questions, is what do I use so I Can get some effects and better guitar sounds? I think the mobile app only works with ios Quote Link to comment Share on other sites More sharing options...
Brazzy Posted October 22, 2014 Share Posted October 22, 2014 (edited) OK, that worked. I can now hear Youtube through the device and also play my guitar at the same time (although youtube is a lot louder do I've had to turn it right down. The next questions, is what do I use so I Can get some effects and better guitar sounds? I think the mobile app only works with ios You'll need an iPhone or iPad to use Moble app. You can use the windows mixer to adjust sound levels, Click on the mixer to see all options >> options> Edited February 23, 2015 by Brazzy Quote Link to comment Share on other sites More sharing options...
MickKnipfler Posted October 22, 2014 Author Share Posted October 22, 2014 Yes I saw that. Not a lot of point really making the device windows compatible but not the supporting software. Isn't there some freeware like amplitube I can use though? Quote Link to comment Share on other sites More sharing options...
Brazzy Posted October 22, 2014 Share Posted October 22, 2014 There might be some free software. You could download the free version of RiffWorks T4. Quote Link to comment Share on other sites More sharing options...
MickKnipfler Posted October 22, 2014 Author Share Posted October 22, 2014 OK, I'll try. Thanks for your help. I'm off to have dinner now and then band rehearsal Quote Link to comment Share on other sites More sharing options...
MickKnipfler Posted October 28, 2014 Author Share Posted October 28, 2014 I've plugged the device in again today and it won't work again Quote Link to comment Share on other sites More sharing options...
MickKnipfler Posted October 29, 2014 Author Share Posted October 29, 2014 Nobody? Quote Link to comment Share on other sites More sharing options...
MickKnipfler Posted January 19, 2015 Author Share Posted January 19, 2015 I'm still having problems. I plug my sonic port in but youtube still plays through the laptop speakers. I can't hear anything from my guitar either Quote Link to comment Share on other sites More sharing options...
