Hollatchaboy72 Posted October 29, 2014 Share Posted October 29, 2014 could I run a Chandler overdrive into the power amp of a sv and have a true tube preamp? Quote Link to comment Share on other sites More sharing options...
BillBee Posted October 29, 2014 Share Posted October 29, 2014 There's a blast from the past - I still have one of those in a box somewhere - real nice sounding. I've never ran the pedal version into anything other than an old Fender Champ but I have used the rack mounted one into various power amps which sounded pretty good. This may sound nuts but IIRC a TS clone in front of the Tube Driver (little to no drive at first) seemed to really beef it up. The grain of salt warning is the IIRC part, I may have been stacking the TS in front of a different OD pedal (it has been years......). FWIW I don't see anything why it couldn't be done to see what it sounds like on the Spider's power amp. I would turn the volume on the pedal way down first though - it may get loud :) Maybe a SV owner who tried this will pop by with thier power amp experience/recommendation. Let us know how it goes. -B Quote Link to comment Share on other sites More sharing options...
Hollatchaboy72 Posted October 29, 2014 Author Share Posted October 29, 2014 Ok thanks,I will! Btw, do u think I should try running it thru the front instead? I have my x3 live running thru the effects loop right now, and I don't want to change that setup, but I want more of a real tube preamp overdrive tone. Quote Link to comment Share on other sites More sharing options...
Hollatchaboy72 Posted October 29, 2014 Author Share Posted October 29, 2014 The reason why im even asking is because I really want the strymon svpre but I can't find one! Figure it might be the next best thing! Quote Link to comment Share on other sites More sharing options...
BillBee Posted October 30, 2014 Share Posted October 30, 2014 Well you can certainly give it a shot - it will depend on how the SV likes drive pedals in front. There is no reason the X3L can't be used as a mod/delay pedal board in the loop with the TD coming in the front of the amp. Don't trip on those cables! :P -B Quote Link to comment Share on other sites More sharing options...
napynap Posted November 24, 2014 Share Posted November 24, 2014 Ok thanks,I will! Btw, do u think I should try running it thru the front instead? I have my x3 live running thru the effects loop right now, and I don't want to change that setup, but I want more of a real tube preamp overdrive ton No, using the front input is not the correct gain stage and won't sound right as I found out --- see post http://line6.com/support/topic/1995-sv-pre-by-strymon/?do=findComment&comment=15577O Quote Link to comment Share on other sites More sharing options...
