criminalpan
Crown xls1000 to spider 412
I have owned a spider 412 for a little while now and just recently purchased a crown xls1000 to run my pod hd500 thru... The stereo connections of the 412 are maxed out at 150w at 8ohms each and the xls1000 is rated at 215w per channel at 8 ohms. So my question is would I be able to re wire the cab to a 300w mono connection and run one channel of the crown into the 412 ? Or should I find something else for a power amp ?
If you keep the volume down on the crown (no more than 1/2), you'll be fine.  But if you accidentally crank the volume too high, you could blow out speakers.
