ericpburt Posted November 30, 2014 Share Posted November 30, 2014 I have the dreaded usb prong death issue with my pod hd 500, so I can not connect to it with a USB cable. I recently upgraded to the pod hd pro, and would like to transfer my saved sounds. Is there a way to do this without the usb, or without going in sound by sound and manually changing? Also has anyone had this fixed, and how much was it? Quote Link to comment Share on other sites More sharing options...
silverhead Posted November 30, 2014 Share Posted November 30, 2014 There is no way to transfer tones from the HD500 to a HD Pro without using a usb connection on the HD500 to get the tones to your computer using HD500 Edit. Unless you have previously saved your HD500 presets/setlists to your computer while the USB connection was working, you will need to recreate from memory your customized HD500 tones manually on your HD Pro. I have had the USB connector on my HD500 repaired. I can't recall offhand the exact amount but I know it was more than $100. It is not a simple matter of replacing the port itself; there's an internal hardware component/chip that also needs to be replaced. Quote Link to comment Share on other sites More sharing options...
ericpburt Posted December 1, 2014 Author Share Posted December 1, 2014 Thanks for the reply. I ended up copying by hand all of my sound chains, just need to do the same for the dials. Is there a better way other than turning the dial a little bit then taking a picture with my phone? Can you push a button and see where all the tone controls are set? Quote Link to comment Share on other sites More sharing options...
silverhead Posted December 1, 2014 Share Posted December 1, 2014 If you select the amp in the signal chain view then hold down the ENTER key you will get to a display of all the amp's tone stack settings. You can also do this with each of the FX to see their settings. As an alternative to taking a kazillion photos I would consider building a quick Excel or Word table to manually record all settings while viewing them as described above. Quote Link to comment Share on other sites More sharing options...
