jatspic05 Posted December 3, 2014 Share Posted December 3, 2014 I am interested in purchasing the sonic port vx. I have a setup that I would like to use and I need to know if this unit can do it. I am looking to run my guitar into my iPad mini then run the iPad mini into my PC DAW. Can the mini usb be used to connect the iPad to the computer for sound or is that port used soley for supplying power to the iPad for charging ? Thank you Quote Link to comment Share on other sites More sharing options...
legrande05 Posted December 3, 2014 Share Posted December 3, 2014 There are drivers you download for the PC. I have done this, but have not gotten it to work with the PC yet. I suspect it should show up as a microphone or line in device. Still looking for solution. Quote Link to comment Share on other sites More sharing options...
joecozzi Posted December 3, 2014 Share Posted December 3, 2014 YES, the mini USB can be used to connect to the computer for sound. However, they cannot both be used for audio at the same time. The mobile device always takes precedence over the computer. Quote Link to comment Share on other sites More sharing options...
Budman2008 Posted December 3, 2014 Share Posted December 3, 2014 You could take the outputs of the sonic port and plug into another computer interface (UX2) "IE" then into your computer or take the output of the ipad into the sonic port and into your computer. The sonic port vx plugged into a computer will only be able to access any plugins you have in your DAW and nothing on your ipad. Quote Link to comment Share on other sites More sharing options...
legrande05 Posted December 3, 2014 Share Posted December 3, 2014 So this is why I am not seeing my sonic port VX when I plug it into my computer or laptop. I have my iPod still plugged in at the same time. If I wanted effects to go into my pc from my guitar, I should connect the USB for power, the ipod for effects and take the headphone out from the sonic port back into the line info the computer, and headphones plugged into the ipod to hear myself play. Or I could run the l/r output to my amp's inputs instead of the headphone from the ipod. Something to try tonight. Quote Link to comment Share on other sites More sharing options...
jatspic05 Posted December 4, 2014 Author Share Posted December 4, 2014 Thank you for the responses! I do run my iPad through a griffin studio connect and then into the focusrite 2i2 into my laptop. I use some of the guitar effects from jamup(bypassing amp models) and use different amp sims in my DAW. I was hoping there was one interface I could use to accomplish this setup. I thought I could do this with sonic port vx! Quote Link to comment Share on other sites More sharing options...
frankencat Posted February 3, 2015 Share Posted February 3, 2015 This is what I am just finding out myself. It is disappointing that you can't record sounds from Mobile POD or Jamup to the DAW on PC. I will probably be returning mine because of this. Quote Link to comment Share on other sites More sharing options...
