victorpainkiller Posted December 26, 2014 Share Posted December 26, 2014 Hi people, i was wondering that is that posible? Sync my pod hd 500 tap tempo with my daw(ableton) . I saw smillar question about that but my tempo sync option is already global. But it's not changing to pod hd tempo when i change my daw tempo. What should i do ? Quote Link to comment Share on other sites More sharing options...
Ed_Saxman Posted December 26, 2014 Share Posted December 26, 2014 Some devices are sending MIDI Clock everytime, as my Boss RC-300 loopstation does. However, using a sequencer like Ableton Live!, it will start to send it as soon as the playback is triggered. Quote Link to comment Share on other sites More sharing options...
victorpainkiller Posted December 26, 2014 Author Share Posted December 26, 2014 Unfortunately, not this time. Don't know what is wrong. Should i do something special ? I mean any DAW setup, something Windows side or soundcard setup? Quote Link to comment Share on other sites More sharing options...
Ed_Saxman Posted December 26, 2014 Share Posted December 26, 2014 In ableton, under preferences, MIDI Sync, MIDI Ports, I think you may need to activate the Sync button corresponding to your output MIDI device. Then, there must be a orange light flashing in the top left when you press play, meaning the MIDI Clock its being sent. Make sure you´re using the same MIDI channel or set it to "omni". Check if you´re connecting the MIDI Out from your interface, to the MIDI IN of the Pod. Quote Link to comment Share on other sites More sharing options...
victorpainkiller Posted December 28, 2014 Author Share Posted December 28, 2014 Cheers man. But it's only working with midi cable, it is unstable (when i set Ableton 100 BPM, POD showing 99.9 BPM) but atleast working. After hit the play Pod setting new tempo. Quote Link to comment Share on other sites More sharing options...
Ed_Saxman Posted December 28, 2014 Share Posted December 28, 2014 I'm glad that you've already got. Yes, the POD HD doesn´t transmits or receive MIDI over USB, and yes, the tempo is drifting a bit, even using a hardware device to send MIDI clock (I´m using the Boss RC-300) There is another posible/theorical way to sync tempo with Ableton, but I don´t know if the POD HD can receive tempo as a parameter, given that the MIDI implementation in the current HD series is way worse/incomplete than in previous POD series was. I think this may be the reason why they have reused the old XT/X3 modelling on the amplifi series, instead the HD modelling. Take a look at this tutorial I wrote to Sync my Boss RC-300 and Ableton Live: http://www.hispasonic.com/tutoriales/sincronizar-boss-rc-300-ableton-live/38381 My POD HD500 is the last in my MIDI daisy chain, so I´m syncing Ableton tempo to the RC-300 sending MIDI CCs, and the RC is sending its MIDI clock to the POD. I dont know if you can extract some ideas from that, but if you find something interesting, please let us know! Quote Link to comment Share on other sites More sharing options...
victorpainkiller Posted December 28, 2014 Author Share Posted December 28, 2014 I want to look at it but i think it is in Spanish. Well i will +/- delay on Midi clock delay option in ableton preferences and i will test abit. If i'm not satisfied with the result gonna look another way. Thx for your help. Quote Link to comment Share on other sites More sharing options...
aro0815 Posted February 5, 2018 Share Posted February 5, 2018 Hi guys, just wanted to share my experiments with Ableton and the Pod (HD500x). Initially I tried to just use the sync function of Ableton, which does work with the pod and does change the tap tempo. But the pod does readjust constantly and this just doesn't work out well. Maybe it's my crappy usb to midi cable... Here's what works well for me: Pod: Midi channel to global (though you could also just limit it to a channel). Ableton: Activate "Track", disable "Sync" of your midi interface. Create a midi clip, which only sends midi information (cc64). You can find this under the envelope settings of a midi clip. I just have it on 127 velocity for one short moment at the start of my midi clip. Now comes what really made a huge improvement for me: Adjust the length of the clip to send the midi information half as fast as your real tempo is, e.g. for drum n bass around 174bpm you would create a clip that's have a bar long and loop it, so the tempo which arrives at the pod is around 87. It won't be exactly that - slightly higher (atleast in my case) - but it doesn't adjust anymore. Now you only have to set your effects to be twice as fast (e.g. 8th -> 16). Just pm me if you have any questions, Greetings, alex Quote Link to comment Share on other sites More sharing options...
