Whargoul Posted December 29, 2014 Share Posted December 29, 2014 I am looking for a way to set some presets to send out of the left output only, some to send out of the right output only, and some to send out of both outputs. So far the only thing I see that might work (don't have second amp yet to test) would be putting a Pan effect in every single channel preset? Quote Link to comment Share on other sites More sharing options...
joebutterfield Posted December 29, 2014 Share Posted December 29, 2014 Since the HD500X output is saved on a global basis, I would use the mixer or pan feature (icon located after the amp on the UI editor) for each preset to tailor your needs. The only way to change different output routing on the fly using HD is through L6 link when connecting a DT or a StageSource Speaker. @line6jbutter Quote Link to comment Share on other sites More sharing options...
Whargoul Posted December 29, 2014 Author Share Posted December 29, 2014 I will be using 2 L2ms. Does that change the answer? Quote Link to comment Share on other sites More sharing options...
