malcevansmusic Posted December 30, 2014 Share Posted December 30, 2014 Just a question for you technical people out there...what is the ideal height to have a pair of L2T's on pole mounts for a gig where people are dancing (standing up rather than sitting) and we're on the floor (not on a stage)? I get a bit nervous when they're too high, but just aware you need to make sure that all the sound's not absorbed by bodies! Thank you! Quote Link to comment Share on other sites More sharing options...
joebutterfield Posted December 30, 2014 Share Posted December 30, 2014 I would suggest that the high frequency driver is right around ear level (5.5-6ft) maybe a little higher if there are more bodies in the room. As long as you have decent stands and the leg base is wider than the speaker it should be fairly stable. @line6jbutter Quote Link to comment Share on other sites More sharing options...
Rick_Auricchio Posted December 30, 2014 Share Posted December 30, 2014 +1. Tweeters are basically what people hear. Quote Link to comment Share on other sites More sharing options...
malcevansmusic Posted December 30, 2014 Author Share Posted December 30, 2014 Thanks. I wasn't exactly sure where the tweeters were. The reason I'm asking is that I've got a sub to top pole that's a bit long and the speaker looks a bit too high. I've ordered a shorter one, based on what you've said, and hope to get the speaker at just the right height! Quote Link to comment Share on other sites More sharing options...
Rick_Auricchio Posted December 30, 2014 Share Posted December 30, 2014 It should be easy to spot the tweeters thru the grill with a flashlight (sorry, I mean a torch for our UK friends)! Quote Link to comment Share on other sites More sharing options...
SiWatts69 Posted December 30, 2014 Share Posted December 30, 2014 I run mine with the bottom of whichever speaker (L3 or L2) at my chin level, which is approx. 5'2 from ground (as I'm 6'2). The deeper the room, the higher I go up to a max of about 6'6 from ground. My aim is to get the horn ABOVE head height for the majority, ie the mid driver at ear height and for the highs to reach the back of the room unobstructed.I have a set of K&M poles http://produkte.k-m.de/en/Speakerlighting-and-monitor-stands-and-holders/Distance-and-extension-rods/21367-Distance-rod-Ring-Lock-black for when I'm running both subs, lay the subs flat then over mount tops on the K&M's, typically on their second notch (approx. 1.2m pole length)When I'm stand mounting them, I have these: http://produkte.k-m.de/en/Speakerlighting-and-monitor-stands-and-holders/Speaker-stands/21467-SPEAKER-STAND-RING-LOCK-black which I run on either their first or second notchCAVEAT: when using poles, please adhere to the Line6 guidance which states:L3s sub with one L2t speaker(on floor or low stage)Use one long speaker pole (notincluded); never use any polelonger than 24-3/4†(626 mm) inthis configuration ;) (this is incidentally for the sub in its upright position, NOT laid flat. I have a pair of Line6 long poles which I use *if* I need to mount with the sub upright). Quote Link to comment Share on other sites More sharing options...
