ColonelForbin Posted January 9, 2015 Share Posted January 9, 2015 Wasn't sure best forum to put this in; went for the M13/M9/M5 since they show it controlling an M5 - along with three other pedals at the same time! http://www.sourceaudio.net/blog/post/source-audio-namm-countdown-2015-reflex-universal-expression-controller "simultaneously controlling 4 different effects pedals from Line 6, Eventide and Source Audio" "Ladies and Gentlemen, this is the The Reflex Universal Expression Controller. The Reflex is a massively versatile and programmable expression pedal that allows its user to simultaneously send up to three standard expression or CV signals, MIDI continuous controller messages, as well as six LFO wave shapes. With the control panel you can program which outputs are active, the depth and direction of the expression signal, and the curve of the tapers. You can also assign one of its six LFO wave shapes with expression control over the LFO speed. Plus, the Reflex can save up to 128 pedal configurations, recallable via the onboard controls or external MIDI program change messages. Now that is power. The Reflex has three standard ¼†expression jacks with a separate set of DIP switches for each. This allows the user to select individual plug configurations or CV (Control Voltage) output mode to accommodate any brand of effects pedal. Reflex also includes a 5-pin MIDI output for sending MIDI CC messages and a USB port so the pedal can be used as a class compliant USB-MIDI device with any digital audio software." Quote Link to comment Share on other sites More sharing options...
ColonelForbin Posted January 16, 2015 Author Share Posted January 16, 2015 I would imagine this could be used to control parameters on an HD500 + M13 + two other pedals? Quote Link to comment Share on other sites More sharing options...
