el_loba Posted January 12, 2015 Share Posted January 12, 2015 buenas! tengo un pod hd300, y un ampli fender frontman 212R 100w. y queria saber como hago para anular o dejar en standby la pedalera y usar solo la distorsion del ampli..... Y si es que no se puede como puedo hacer para dejar un canal de la pedalera lo mas limpio posible para activar la distorsion del ampli en ese canal....gracias gente!! Quote Link to comment Share on other sites More sharing options...
pianoguyy Posted January 13, 2015 Share Posted January 13, 2015 Me disculpo de antemano por mi español. No hay derivación de la HD300. Hay dos cosas que usted puede hacer: 1. enchufe el HD300 en el fx loop del Fender. Entonces, cuando se desea utilizar sólo el Fender, puede activar el bucle. 2. Dejar un espacio en blanco predefinido en el HD300. Siempre que quieras un "no-efecto", que es lo que usted haga clic en. Quote Link to comment Share on other sites More sharing options...
pianoguyy Posted January 13, 2015 Share Posted January 13, 2015 and for those lacking in foreign language skills, or an online translator... he sometimes wants to use just his fender and was wondering if there was a standby mode. I told him to plug the pod into the fx loop of his amp so he can bypass it that way. Or he could use a blank preset to get a 'no effect' effect. Quote Link to comment Share on other sites More sharing options...
el_loba Posted January 19, 2015 Author Share Posted January 19, 2015 muchas gracias! lo voy a intentar Quote Link to comment Share on other sites More sharing options...
el_loba Posted February 2, 2015 Author Share Posted February 2, 2015 perdon por mi ignorancia, pero como hago para dejar un espacio en blanco? selecciono el modo clean de la pedalera? gracias! Quote Link to comment Share on other sites More sharing options...
pianoguyy Posted February 2, 2015 Share Posted February 2, 2015 cualquier ranura marcada " nuevo tono " debe estar vacÃo de nada Quote Link to comment Share on other sites More sharing options...
