seeeeeebi Posted January 18, 2015 Share Posted January 18, 2015 Hi, I'm pretty new to computer recording and I have this problem that drives me crazy - hope you can help me! I started recording a song in Cubase (7 LE) a few days ago, using an UX2 and recording the dry signal. Now I'd like to continue work on the project, but any new recording I do seems to create a different dry signal, so that the result doesn't match the rest of the song. The signal seems to have more amplitude and also a tendency for annoying overtones in it. I haven't (at least not intentionally) changed anything in the setup - guitar volume set to max level, same strings, same cable, same port. Any idea what could cause this? Could this be a problem on the Cubase side? Or an hardware issue? Thanks! Sebastian Quote Link to comment Share on other sites More sharing options...
fflbrgst Posted January 19, 2015 Share Posted January 19, 2015 Are you saying that the previously-recorded track is changing, or that when you record a new (dry) track it sounds different than the previous one? Quote Link to comment Share on other sites More sharing options...
seeeeeebi Posted January 22, 2015 Author Share Posted January 22, 2015 When I record a new track or add new recording to the existing project, the new dry signal sounds different than the previous ones Quote Link to comment Share on other sites More sharing options...
fflbrgst Posted January 23, 2015 Share Posted January 23, 2015 If everything is the same - guitar, cable, and UX2 settings, something is affecting the recorded signal somehow, I'd look for settings or a plug-in you are not aware of being activated. Quote Link to comment Share on other sites More sharing options...
