jonpaulleclair Posted January 26, 2015 Share Posted January 26, 2015 Greetings... did a quick search around couldn't find an answer so I'll post. Forgive me if I missed and obvious reply to this question. My son's G30 is no longer transmitting a signal. Bought it in mid 2013 and has worked like a champ. Within the last week at a show, his bass started cutting out during a show and we quickly switched over to a cable. This past weekend during set up, he had no signal whatsoever. The receiver and transmitter both show good connection, tried different channels, walked through his signal chain to verify nothing else was interfering, and narrowed it down to the wireless unit. Batteries are good. Our guitarist had an extra G30 transmitter, fired his transmitter up and tried it, worked just fine. I see there could possibly be a firmware update for it (not sure if that'd fix anything), but doing so could be difficult locating the required receiver to perform it - short of sending it in to Line 6. Purchased in mid 2013, have extended warranty on it from GC. Any suggestions? Quote Link to comment Share on other sites More sharing options...
dboomer Posted January 26, 2015 Share Posted January 26, 2015 My best guess is that the input jack has become damaged. I would suggest that you consult with GC as to weather that is covered. Quote Link to comment Share on other sites More sharing options...
jonpaulleclair Posted January 27, 2015 Author Share Posted January 27, 2015 Thanks for the response. I'll check it over. I was thinking that as a possibility as well. Thank you! Quote Link to comment Share on other sites More sharing options...
