dovilas Posted January 28, 2015 Share Posted January 28, 2015 Hello, i have recently purchased a POD Studio UX2 , I also installed all the software it came with, the problem is - when i try to login to License manager to activate(?) the POD Farm it keep giving me a message ~Login failed. (code 8000200b) the attempt to secure the connection failed~ I couldnt find any related problems on the forums. I also turned off my firewall and antivirus before trying to connect. Please help ! thanks ;) Quote Link to comment Share on other sites More sharing options...
Brazzy Posted January 28, 2015 Share Posted January 28, 2015 when i try to login to License manager to activate(?) the POD Farm it keep giving me a message ~Login failed. (code 8000200b) the attempt to secure the connection failed The problem could be with the firewall in your cable router. Maybe someone who has more definite answers will help. If I think of anything else I'll post it. I did a search and found this archived thread that may help some: http://line6.com/supportarchivenew/thread/75707/ 1 Quote Link to comment Share on other sites More sharing options...
dovilas Posted January 29, 2015 Author Share Posted January 29, 2015 Thank for the link, it actually helped. I had to reset the internet connection;s settings. Althoough i have to do it everytime i want to log in to license manager. well its still better than nothing. Thanks Quote Link to comment Share on other sites More sharing options...
Brazzy Posted January 29, 2015 Share Posted January 29, 2015 Thank for the link, it actually helped. I had to reset the internet connection;s settings. Althoough i have to do it everytime i want to log in to license manager. well its still better than nothing. Thanks Cool, I had a similar problem with RiffWorks. When I wanted to upload a finished track it wouldn't go, just stopped in it's tracks when I clicked on the RiffCast button. So I did some digging around in the Cable Router software to find out they added or changed the software and I could select a lower level of firewall to get it through. When I'm done I change it back to higher level, lol. There's probably an easier way but I'm good with it. Quote Link to comment Share on other sites More sharing options...
dovilas Posted January 30, 2015 Author Share Posted January 30, 2015 hehh, i guess i was too quick to feel happy that its working.. Today i tried a couple of times to reset the internet settings and license manager couldnt connect again. oh well. at least i authorised my POD Farm before. Quote Link to comment Share on other sites More sharing options...
Brazzy Posted January 30, 2015 Share Posted January 30, 2015 hehh, i guess i was too quick to feel happy that its working.. Today i tried a couple of times to reset the internet settings and license manager couldnt connect again. oh well. at least i authorised my POD Farm before. I found this 'cause I thought there was way to do it offline. Not completely but here it is: Can I authorize my POD Studio UX2by psychometalhead on 2012-02-21 20:08:52 I don't have access to the internet on the computer in my studio and I need to authorize my interface ASAP. Re: Can I authorize my POD Studio UX2 by Line6Don on 2012-03-08 09:38:04 First off, you would need access to a computer that is connected to the internet so that you could download the most recent version POD Farm 2.51. You can download them from the links below: Windows POD Farm 2.51: ">http://line6.com/software/readeula.html?rid=4147">http://line6.com/software/readeula.html?rid=4147 Mac POD Farm 2.51: ">http://line6.com/software/readeula.html?rid=4149">http://line6.com/software/readeula.html?rid=4149 Once you have downloaded this file, you will need to install it onto your computer and then authorize it. We have a video tutorial that will show you how to download and install POD Farm, and then use the License Manager to authorize your computer: ">http://line6.com/support/docs/DOC-2499">http://line6.com/support/docs/DOC-2499 Once you have installed it onto your online computer, you will need a way to bring the POD Farm software and authorizations to your offline computer, by burning the file to a CD/DVD or using a external hard drive/flash drive. After obtaining your transferrable medium, you will need to put the POD Farm 2.51 file that you downloaded on the medium as well as the authorization files. For instructions on how to locate and transfer the authorization files, check out the video tutorial we have for this process located towards the bottom of the following document: ">http://line6.com/support/docs/DOC-4738">http://line6.com/support/docs/DOC-4738 Once you get the file onto the transferrable medium, bring it to the offline computer and install it. Once POD Farm is installed, you can place the authorization files in the same place that they were located in on your online computer to authorize POD Farm 2 on your offline computer. Quote Link to comment Share on other sites More sharing options...
dovilas Posted February 2, 2015 Author Share Posted February 2, 2015 I managed to find another solution. went to internet options>connections>lan > and unticked the proxy thing and enabled automatic detection. everything works like a charm right now Quote Link to comment Share on other sites More sharing options...
Brazzy Posted February 2, 2015 Share Posted February 2, 2015 I managed to find another solution. went to internet options>connections>lan > and unticked the proxy thing and enabled automatic detection. everything works like a charm right now Good Deal!!! I had that issue quite a ways back. Forgot all about that setting. Quote Link to comment Share on other sites More sharing options...
