AKG C519ML mic with XD-V75 and TBP12 Beltpack
This for information only in the hopes that it assists someone else...
I own an XD-V75BP wireless kit with the TBP12 transmitter.
I am a sax player (though some might disagree ;-) )
My current setup is for Bari sax and consists of:
2x AKG C519ML micromics (TA3F connectors)
1x AKG B29L minimixer and phantom power supply
XD-V75BP Wireless.
In this full gig setup, the connections are all simple:
TA3F to TA3F cables connect each micromic to the B29L
XLR-F to TA4F cable connectos the B29L to the TBP12.
The XLR-F to TA4F cable is wired as:
XLR pin 1 = TA4F pin 1 (cable shield)
XLR pin 2 = TA4F pin 3 (audio +)
XLR pin 3 = TA4F pin 1 (audio -)
No connection to TA4F pin 2 or pin 4
This wiring is identical to the Shure WA310 connector
TA3F to TA3F cables for the micromics when used with either the B29L or an AKG wireless kit (I was using an AKG Perception WMS45 rig prior to acquisition of the Line6 rig) is:
Pin 1 + sleeve
Pin 2 + Pin 3
I have previously enquired before about connections for making up a cable so that I could run just a single AKG C519ML with my TBP12 and subsequently tried but failed. I wanted the option of being able to run with just one mic for rehearsal etc, or if I was playing tenor (which only requires a single mic). At the time I gave up on the quest but have recently returned and done more research.
What I have now succeeded in is in matching the impedances to allow my AKG mic to work with the TBP12.
From the TBP12 Pilots guide:
TBP12 Beltpack Pinout To TA4F Connector
Use the following wiring protocol when using other headset, lavalier, or instrument microphones or
cables with the TBP12 beltpack transmitter.
• TA4 pinout
• 1 = GND
• 2 = V+
• 3 = Signal
• 4 = Z (This pin is tied to Signal for lav mics and tied to Gnd or open for gtr)
You can either make a TA3M (male socket) to TA4F plug adapter or make a TA3F to TA4F cable of the required length. My personal choice has been to make up a short adapter piece as it aavoids confusion with cables in my gig bag.
Wiring is as follows for a TA4F to TA3M Adapter cable:
Parts required:
REAN (Neutrik) RT3MC-B Tiny XLR Male
REAN (Neutrik) RT4FC-B Tiny XLR Female 4pin
Length of quality 2-4mm diameter microphone/instrument cable;
4.7Kohm surface mount (SMC) resistor
Pin 1 (TA4F) -> Pin 1 (TA3M)
Pin 2 (TA4F) -> 4.7Kohm -> Pin 3 (TA4F)
Pin 3 (TA4F) -> Pin 2 (TA3M)
Pin 4 (TA4F) -> Pin 3 (TA4F)
TA3M
Pin 1: Shield
Pin 2: Audio
Pin 3: No connection
TA4F
Pin 1: Shield
Pin 2: Bridge to Pin 3 through 4.7Kohm resistor
Pin 3: Audio
Pin 4: Bridge to Pin 3
Wiring is as follows for a TA4F to TA3F cable: (direct connection of mic to TBP12
Parts required:
REAN (Neutrik) RT3FC-B Tiny XLR Female
Pin 1 (TA4F) -> Pin 1 (TA3F) + sleeve
Pin 3 (TA4F) -> Pin 2 (TA3F)
TA3F
Pin 1: Shield and bridge to connector sleeve
Pin 2: Audio
TA4F
Pin 1: Shield
Pin 3: Audio
I have quoted REAN connectors but you can use any mini xlr connectors available to you. I just happen to like working with the REAN ones :-)
The mic/instrument cable needs to be 1 way shielded. You can use 2way if you like but there is no connection via the 2nd signal cable.
I use Van Damme Pro Grade Classic XKE flexible 1 pair p/n 268-100-000 which is 3.6mm o/d. You could also use Van Damme Pro Grade XKE Unbalanced Pro-patch cable but it has a larger 4.5mm o/d and isn't as flexible. Just ignore one of the pair cables in the 2 pair cable!
For surface mount resistors, if you choose 1206 pattern/mount (approx. 3.2mm x 1.4mm) these will solder directly between the pins in a TA4F connector :-) Use solder paste for this job otherwise it is really fiddly!
PLEASE NOTE: The above is correct ONLY for the AKG micromic series; AKG C519ML, AKG C519M, AKG C518ML, AKG C518M, AKG C516ML, AKG C516M and the AKG C411.
For mics from other manufacturers, the resistance required to bridge pins 2 onto pin 3 will very likely be different.
Hope this helps someone... took me long enough to get it nailed!
<edited>I cocked up when writing the above out. It is now corrected</edited>
  • 3 weeks later...
  • 4 weeks later...
  • 2 years later...
Thanks a milion for this topic!!!
Works with my AKG C411 PP (modified into C411 L) and with Schertler Stat-V (electrostatic transducer which also needs phantom power).
How did you get this to work with the Stat-V. I'm looking to bypass the preamp that comes with the pickup. Will I need to modify the custom cable that comes with the pickup???
  • 2 weeks later...
Well, first of all if you want to get an original Schertler cable, the price is ridiculous...:
https://www.thomann.de/pl/schertler_ca_stat_v_kabel.htm
So get yourself just the "binder" connector, or fifty connectors for the price of one original Schertler cable:
https://www.binder-connector.com/en/products/subminiature-circular-connectors/snap-in-ip40/
and a Neutrik-Rean RT4FC-B connector (or TA4F by Switchcraft).
And I did it like this (Binder connector used in Schertler Stat-V pickup):
