I'm i right : the HD500X is like a Guitar Ampli ?... need cabinet ...
Segomil
Hi !
If it's the case, i really need a cabinet to plug to my HD500X...it's for my JTV69 & Strat fender ...
The goal is to save my Presonus Eris 8 (for recording use)... It's for home studio, i do not need a powefull cabinet.
The cabinet will be place between the 2 Eris 8 .
Any suggestion will be appreciate !
Now the question is : how to redirect the guitar signal through the cabinet only & for the midi through the Eris 8 (midi signal) ???
I'm dead because i try many time to have micro & guitar signals in different channel to play together without having the same effect FX ... & i have failed I'M DEAD !
Thank you all
Daniel
Not sure I understand your second question. I think you are attempting to put two devices into the HD500X, perhaps a guitar and the output of a MIDI keyboard. And you want different effects on each device. To do that, you would leverage the A and B signal paths in the HD500X. Set the input for the A path to Guitar, and probably Aux for the keyboard. Put all the guitar effects and amplifier blocks in the A path, and all the keyboard blocks in the B path. Then use the mixer at the end of both paths to blend them together.
