fflbrgst 1,844
I assume you verified the power cord is not loose. I think in hte past people have detemined it is a bad component or solder joint in the amp that is causing the problem (when it heats up, it expands and power goes off) which would require servicing at an authorized service center.
Jimmikatt 26
Temp seems not to matter, it will go a week without shutting down,
then it will do it 3 or 4 times within a 1/2 hour, it's not consistent, nor can i recreate the malfunction, it's all quite random.
fflbrgst 1,844
What is your power supply like? I've heard of people curing this problem by using a conditioned power supply (like a Furman conditioner) because their electricity voltage was actually varying quite a bit.
Jimmikatt 26
That could be a possibility, as it's just plugged into the wall outlet.
I should test it out with a spike strip, or conditioner and see what happens.
Thanks for the idea.
Also check out my link at the bottom, got a new song, using the Spider lV 75 on both guitar and bass...lol
I have a spider IV and it also randomly shuts off and comes back on - like a reset. I have temp'd componets and nothing seems to be running hot. Happens randomly sometimes 3 or 4 times in a row. Very aggravating in live performance. It's not the electric, amp worked fine for a long time, now it resets everywhere I play it.
One possibility could be the power switch. Recently my amp wouldn't turn on at all so I replaced the power switch in it and now it works fine.
Jimmikatt 26
4 months to the day that i made my 1st post about the amp problems it died.
Hate to say this, but my Spider lV 75 just started having the off and on issues.
I have done the factory resets, disconnected my shortboard, checked for updates, but nothing helps.
what is causing this problem.? i know many have had this issue, and what needs to be fixed.?
I can't have this going on while i'm recording.
