Texas53 Posted March 7, 2015 Share Posted March 7, 2015 Getting back into electric guitars after a 30 years break and trying to learn all the new stuff. :) I have a Spider IV 150 and the FBV Express MK II. Reading thru the documentation to understand the FBV and really confused. Some places the documentation talkes about changing the bands, others talk about programs and channels and folders... AAAAAHHH I need a translation... Quote Link to comment Share on other sites More sharing options...
Mr_Arkadin Posted March 7, 2015 Share Posted March 7, 2015 It might help if you point to what you don't understand (i.e. tell us the document and page number etc.) and also what you want to achieve, as at the moment those terms are too wide-ranging to give you a specific answer. Mostly you're just changing presets (sometimes called patches) on the Spider with the footswitches. For some reason I've never understood, Line 6 refer to these presets as Channels (I think they were thining of amp channels, but I never thought it made much sense). 1 Quote Link to comment Share on other sites More sharing options...
fflbrgst Posted March 9, 2015 Share Posted March 9, 2015 There are song and artist/band preset patches that you can access through the 4-way switch and preset knob on the amp (you can't access these via the FBV MKIV Express). The Express allows you to select the 'channel' (A, B, C, D) of the particular user bank you have selected on the amp. 1 Quote Link to comment Share on other sites More sharing options...
Texas53 Posted March 10, 2015 Author Share Posted March 10, 2015 The Express allows you to select the 'channel' (A, B, C, D) of the particular user bank you have selected on the amp. yea, I finally figured that out... the documentation is clear as mud... Which midi command do I use to get to bank 16? I have tried every combination that I can glean from the documentation and all I can get it to do is walk thru the ABCD of whatever bank comes up when the amp powers up.... I do appreciate the guidance.... Quote Link to comment Share on other sites More sharing options...
Texas53 Posted March 10, 2015 Author Share Posted March 10, 2015 Ok, I think I got it... Must run the Spider IV edit in the same "session" as the MKII setup... I set up the sounds yesterday and tried to set the MKII up today without rerunning the editor.... Quote Link to comment Share on other sites More sharing options...
fflbrgst Posted March 11, 2015 Share Posted March 11, 2015 You can load your tones using Spider Edit, or from the front panel of the amp. Quote Link to comment Share on other sites More sharing options...
