How connect 500x to mix via XLR cabel and how connect 500x to audiobox box via XLR cabel
tonix94
How connect 500x to mix via XLR cabel?
output it is balanced R/L but i not understand how conect two cabel to one input?
I have a mix http://www.artist.ba/images/product/Behringer_UB802_photo_1.jpg
Berhinger UB802, this mix have a 2 inputs.... Then is shem a H500x (balanced out R/L XLR) to UB802 ( to two imputs) ? :D
but
how connect 500x to audiobox box? H500x utput it is balanced R/L RLX but input on audio box it is (mic. XLR and Instrument XLR)....how a connect this davice? It is a L into the mic and R into in instrument? Or a not corect?
this auido box a like this http://c1.zzounds.com/media/quality,85/audiobox_usb-a-73c35f09e72f739e2db30a22b43e7a87.jpg
A have can not connect in this davice my hd500x because is input mic and instrument or is two inputs (chanel) same?
But a can not like this (how I imagined),i need to buy higher device? like this? http://cachepe.zzounds.com/media/quality,85/audiobox44vsl-front-6f13c5236b9f7089b721ce1885d86528.jpg
going to a mixer is easy.
Take the two XLR jacks and plug them in.
Guitar ==> Pod ==> Mixer
fairly simple
but
the 2 wires in the xlr are + and -  of 1 mono signal.
according to your mixers manual, its 1/4 inputs are balanced and can also  take unbalanced mono signals.
so 2 plug adapters from  xlr ==> 1/4" `will work.
connect pod xlr to channel1 and ch.2. pan them left and right for stereo or both center for mono.
or connect pod 1/4" L+R outs to channel1 and ch.2.  pan them left and right for stereo or both center for mono.
your audio box appears to be mono.
pan both your mixer channels to one side and take that output to the audiobox.
using the audio box will introduce additional latency.  the pod can also be used as a audio interface instead, without the 2 external devices.
