Set list names don't change
rd2rk
Updated to 1.4/2.6. Did a system reset. Did a pedal recalibration. Opened edit. Loaded my bundle. Sent it to the 500x. All presets sent, but the set list names won't change. Did it (reset, recal, send bundle) twice, Set list names remain the same. Yes, I know it can be done manually from the unit. PITA! Especially if you've got multiple bundles with different set list names! Anybody know what's happening here and how to fix it?
Realzap - sounds like you're taking about renaming a setlist in edit. How do you even do that? Anyway, irrelevant, as I'm loading a bundle with already named setlists.
Thanks, Realzap. I couldn't get it to work with f2, but figured out that it works the same way as renaming a preset - click pause click again, type name, press enter. When I made this bundle (my first), I'd used a lot of presets from customtone, saving and naming the set lists from the FILE Menu as I went, then bundling them. When I got the new amps I wanted to start fresh, so I tried to figure out how to "Clear" the set lists I didn't want. I wound up writing over all the presets in a set list with "New Tone", saved (from FILE Menu) the set list as BLANK SETLIST, then opened it in each of the set lists I wanted to clear. I saved it with a new bundle name, then loaded the new bundle. The save/bundle process renamed all the cleared set lists Set List 1, Set List 2, etc.(maybe it truncated the BLANK from the name and added a number?), which was OK by me. But when I sent it to the POD, although the presets sent fine, none of the set list names overwrote the names from the upgrade. No idea why that happened, but when I changed the names manually in Edit, they changed on the POD and were saved, no send process required. Anyhow, it's all good now, thanks for your help!
