mersus Posted April 12, 2015 Share Posted April 12, 2015 Hello my doubt is the following one: I have an amplifier line 6 spider IV of 120 watts and a FBV MKII shortboard express, theproblem is that sometimes it stops being listened, I extinguish it and light it again and allgood, I believe that it is because the cable ethernet is defective but I would like to know thatthis owes and if it has repair thanks !! Quote Link to comment Share on other sites More sharing options...
mersus Posted April 12, 2015 Author Share Posted April 12, 2015 Que tal mi duda es la siguiente: tengo un amplificador spider lV de 120 watts y lo que para es que a veces se deja de escuchar sin razon aparente, sigue encendido pero no emite ningun sonido, lo apago y vuelve a sonar, a que se debe esto? yo pienso que es porque el cable ethernet no se encuentra bien conectado, si es problema de el Mkll express, del cable o del amplificador... gracias por su atencion !! Quote Link to comment Share on other sites More sharing options...
fflbrgst Posted April 13, 2015 Share Posted April 13, 2015 First things to check are the cable and the connectors - both the one into the FBV and the one into the amp. Check for any bent pins. Quote Link to comment Share on other sites More sharing options...
